POOLEX JETLINE 120 PROBLEME DE MISE EN ROUTE
BONJOUR
JE ME LANCE DANS LA MISE EN ROUTEE MA POMPE A CHALEUR
POOLEX JET LINE ELLE DEMARRE MAIS NE CHAUFFE PAS
BRANCHEMENT ELECTRIQUE CORRECT BRANCHE EN ASSERVISSEMENT
VANNES BIEN POSITIONN EES MAIS CODE ERREUR E ET LE MANOMETRE EN MARCHE INDIQUE 230
L EAU NE CHAUFFE PAS A LA SORTIE DE LA POMPE A CHALEUR ET NON PLUS AU NIVEAU DU REFOULEMENT PISCINE
QUELQU UN AURAIT IL UNE IDEE DU DISFONCTIONNEMENT
MERCI PAR AVANCE
MERCI PAR AVANCE
